Just starting to run these coffees through their paces. So far the first really solid recipe I have settled on is with the Los Naranjos for Chemex.
-32g coffee, 3 days off roast
-480g water
Using a scale to weigh the entire process:
-wet all grounds using 40-50g water at 175f
-pause 30 seconds
-between 31-60 seconds pour continuously, circling outward to saturate all grounds evenly maintaining an even surface color
-at 60 seconds pause, volume should be 1/2 up the filter, 250g total weight
-at 80 seconds pour again, starting around the outside to bring the clinging grounds back into the slurry. Try not to raise the volume beyond the initial max volume
-at 120 seconds pause, 325g total weight
-at 135 (2:15) seconds pour again, repeating the previous steps
-at 180 seconds your kettle should be empty
-flow rate should slow to dripping at 4:00, remove filter when flow slows to dripping regardless of time, but aim for 3:45-4:00
We've been very happy with the results! Reminds me of "fruit medley" herbal teas. Things like blood orange, hibiscus and rose hips come to mind. As the cup cools it turns creamier, gaining a caramel-like sweetness but loosing none of it's tropical notes. At room temperature it reminded me of an orange creme brulee I had at a local dessert shop a couple months back.
http://www.compasscoffeeroasting.com/blog/coffees/single-origins/colombia-bry
