by orphanespresso on Tue Feb 08, 2011 6:27 am
Isn't that a beautiful little seemingly over complicated device?? Just count the number of tiny parts in there...amazing! From what I could tell, tightening the brass rod increases the tension on the spring which counters the water flow into the cylinder....or restricts the water entrance into the cylinder. Loosening the brass shaft allows the water to flow faster into the cylinder. That was my observation at least. The purpose of this is of course up for discussion and it can only be some type of flow control for preinfusion...or general flow into the cylinder. Astoria groups have a large ball bearing and spring behind the group that restricts the flow form the hx and dipper tube groups have the 10-12mm dipper tube ending in a pinhole at the group for flow restriction (not adjustable).
It is my opinion that the Faema flow control is just another example of the extreme adjustable mechanism of the Zodiaco group. The metering rod on top of the group rear has to do with the thermosyphon flow, but the lower mechanism is, as far as I could determine experimentally, the water flow into the cylinder control since it could completely shut off the water when tightened all the way down.
Nice new parts you have there by the way, and well laid out.
