I had to disassemble mine (it's hard to remove the heat element as the space below the machine is very tight) to paint it. But as a powder coat shop painted the machine, it was sand blasted and then painted blue.
But the guy painted the interior too and I have to remove it... Now, even if I took it back to the guy to remove and repaint, as powder coat is very resistent, he'll need to let it at the paint remover before sand blast again...
So I have the same doubt as you, Yuwen, if I could use some remover. I think it should be fine, to remove the paint, then after that some grit paper coarse to fine to polish the aluminum.
Keep in mind that maybe the aluminum will start to "rust". Probably you have something like that (pitting) at the piston sleeve, right?
Beautiful machine, strong spring, simple desing... But some fails on design that give headaches. For instance, the top cap of the piston sleeve scratches the piston rod. The screws of the piston sleeve are some kind of steel and they rust bad if you don't protect them. Mine came with a chromed spring and there were 2 rusted scars - I did the chrome again, but I really don't think it will last.
I thought about making the top cap hole wider and making a teflon sleeve to the piston rod.
As Francesco says, it's a machine to use with care.
Márcio.
