by orphanespresso on Mon Dec 13, 2010 7:48 am
Hi Roman....worry on the slow reply to your emails but have you heard the "no water no coffee" slogan? Our well pump died 6 days ago and we have some dire days here.....we have a lot of snow and our well is about 1/4 mile downhill from our house and the well guys came up with the following plan.....remove all the snow, get a bulldozer to aid in the giant pump pulling truck to get to the well, they pull the well out (320 feet below the surface), install a new pump and all the pipes, and have the bulldozer standing by to pull them out of the jobsite.......oh yes, and one more thing, the ground has to be frozen! We have had a warm spell here and we have forecast sub freezing temps for Friday so only 5 more days with no water but melted snow, which by the way makes CRAPPY coffee.
Bet enough of our travails.....I think what you can do is bypass the gicar for now and work out the pstat circuit, or even check to see if the pstat is working. Since it is 220, wire from the switch directly to the pstat then to the heating element and back to the switch with the gicar taken out of the circuit for now. This will solve the more pressing issue, the pressure control system. Since the gicar unhooked should not change the pstat and heating element function you can figure that out later but manual fill is not all bad, although runaway heating is not all that good.
Like I said before, draw the wiring diagram and look for some phantom circuit. Look forward to the full photo show.
