by orphanespresso on Thu Aug 13, 2009 5:14 am
The idea of a fuse or no fuse is a red herring since the fuse on the boiler plate on many models is a THERMAL fuse set to blow or melt at 145C, not a overload amp fuse, so this is not an issue. To check the element to assure yourself that it is OK unhook all the wires and test ohms accross the contacts on the element ends (look at the element and check ohms on that coil....for some reason you have two elements in the base on this pro, which is odd as they usually have but one coil on a pstat equipped machine, so some change has been made to along the line on this machine). Seems to me you have an old style Europiccola element in it and an added pstat. Odd duck all around for sure. On the element you should get some ohm reading, not 1 or 0 but some number, one higher than the other, this is good.
To make the machine work right, first check the switch, it should be a DPST switch, so when it is in the off position there is no continuity between any of the poles and when on there should be continuity between the contacts on one side and the other side, in pairs as it were. To properly wire these 4 prong switches, your two wires on the cord go to the cold side of the switch. On the hot side of the switch one wire goes to the pstat and then to the element, and the other wire (the neutral) goes to the other post of the element. Since you have an oddball element for that switch (the dual element usually takes a 6 prong switch, not 4) you need to join up the terminals on the two elements into one by bridging to make what would amount to a single element in the circuit.
This will make much more sense when you draw a wiring diagram. Pencil and paper and stare at it.
Also, this type of element had a thermal safety switch which is the kind that you may see shielded in a silicone tube and is held against the boiler by use of a brass bar which bridges two of the element posts. This fuse wire begins at the neutral side of the switch and terminates on the neutral side of the element.
Also, I see no ground wire in your photo, which should be attached to the boiler plate by a small screw. This machine is either a Europiccola with an added pstat or a pro with an added europiccola element, but either way there is some sorting out to do.
