I was able to pick up a couple of Cremina's recently, (a '70 and a '76) and thought I'd share a couple of pics and pose a couple of questions.
First of all, the insulation on the '70 is interesting - it appears to be a rubber based foam of some sort.
I've poked and prodded it and it looks like the whole coating will peel off cleanly if I chose to remove it.
I'm leaning towards stripping it off, simply because it looks a little gross. Anyone out there think this is a bad idea? I can't help but think that if I want to insulate the machine I can just pick up a kit from OE that will likely do a better job anyway...
On to the electrical, this Cremina has an interesting recessed plug fitting (see below):
It's got a ground wire connected to the frame, but looks to only accept an ungrounded power cord (it didn't come with a cord, I've gotta source something). Can someone shed some light on this set up for me?
I was thinking I could swap in a standard 3 prong receiver (like those found on the back of LCD monitors/DVD players/etc.,.), provided I can find one with the correct fit. Am I being over reactive? Will this machine be grounded if I just dropped in a 2 prong power cable?
Thoughts, suggestions and opinions are (as always) welcome.
Thanks everyone,
-GB.
