peacecup wrote:Right, 7g:25ml, this is a 28% shot. So 14g:50 ml would fit the bill as a traditional doppio. Sorry, I said 60ml, but I was thinking in ounces, which is the regular old 2 oz doppio. By IENI standards this is NOT a lungo, its a doppio espresso. My point was that Andy's brew ratio chart somewhat REDEFINES the traditional terminology, albeit it is more precise. For example, Andy's "regular espresso, single, med., at 7g, only produces 14g of liquid - the IENI definition would be 20+g (unless the shot was all crema).
So...I'm saying that an IENI double has a lower brew ratio than does Andy's double. Because the majority of posters here on HB tend towards following Andy's guidelines, they're more accustomed to "ristetto-ish" doubles. Hence, when they taste a traditional double they find it less palatable. Its like switching from strong ale to lager. I think this is why I could not get any of the Ponte Vecchio reviewers to seriously evaluate shots in the 25% brew ratio range.
That's my point: unless you know whether the volume is crema or liquid, it's hard to make reasoned comparisons. I'm a big fan of Andy's brew ratios because a) it's hard to measure volume as precisely and reproducibly as weight and b) it takes crema production out of the equation.
On pump machines that extract with 9 bars of pressure, you can expect nearly 100% crema to pour into the cup. I have no argument with the traditional IENI definition of espresso, assuming that the 25ml single or 50ml double is mostly crema. This shot was pulled as a 50ml double, but would eventually settle to 30ml or less. I'm sure the brew ratio was (slightly) over 50%.
Bottomless pour on a Vetrano rotary pump machine.
[Edit: irrelevant pix deleted.]
Unless all our shots are the same density (same amount and type of crema), claiming 14g and 50ml is a normale double is rather vague. My apologies to the IENI, but it's much more precise to specify a 50% brew ratio.
Kudos (again) to Andy for his attempt to quantify our espresso terminology with brew ratios.
