peacecup wrote: ...
Incidentally, I have a VAM that has the heavy-duty piston like the one on the far left, but with a hole in the piston face. That makes at least six different piston designs!
noah wrote:Just replaced it again, this time with some DOW 111. When I refilled the kettle, I noticed something I had forgotten previously - that the leak is connected with how full the kettle is. If the kettle is only about 1/4 full, then no leak, but beyond that, there is leaking, even with the new ring.
Also, there is a water line, a discoloration if you will, at this point beyond which there will be leaking - I wonder whether or not this has always been a problem with this machine - or whether there is more than the small o-ring at play here.
michaelbenis wrote:
I suspect [leakage is] nothing to worry about.
