Ben Z. wrote:It has been perfected - in the Caravel. Stamped and welded stainless sheet metal and a lightweight aluminum casting. Form, function, manufacturing cost, and maintainability - all optimized.
TUS172 wrote:So you think it is easy Hmmmm... Ever used a lathe or milling machine? Ever looked at the price of a 4" X 6" block of brass?
The intricacies involved in machining a grouphead are complex and very multifaceted. I have owned lathes and milling machines and worked with metals for years. It takes expertise and knowledge to know what processes need to be done in the correct order so that you don't end up with a piece of useless junk half way through the project. And tolerances tighter than you think to make a well functioning grouphead.
Don't get me wrong ... It can be done... but it is not a simple task.
five and dime wrote:What about something seemingly simple like bolting and Astoria or CMA group to something small like the Sama/Pontevecchio Export boiler....It might be as simple as drilling a new bolt pattern on the boiler flange? Both groups use dipper tube designs.
<img>
kitt wrote:even my commercial levers have a tendency to tip forward
truemagellen wrote:I like that machine alot...I personally prefer their Elisse model for looks. The problem with it is a 5 liter boiler and 1400w....just seems like that is undersized, probably the 220v is properly sized.
Besides you can get a Rancilio Classe 6 leva for close to that price right now if you import...which is a very good looking machine (performance unknown to me).
If I were to go for the home I'd get the Ponte Lusso 2 gruppi...and uprade the heating element.
But I want to make one on my own partially for looks, I want to make a modern looking lever...high tech looking. Only the Rancilio's HL cube like thing has sort of fit the bill and I cannot find those anywhere....I'm thinking industrial looking but clean links Keeys designs are two retro looking for me and besides $$$$$$$$$$$
<image>
<image>
