peacecup wrote:Too big anyway Ed. Not sustainable to keep all that water hot to pull 2 oz of it through a few grams of ground coffee every few hours. If you can find a one-group with a small enough boiler you'd be ok. I speak from experience - I have a 2-group Rancilio Z-11 (not lever) sitting on the bench, but I can't really justify refurbishing it unless I want to heat the garage with the massive boiler (not a bad idea, if it were only a lever). Since I have the Sama back up and running I've lost the motivation however.
But I thought you had a Bezzera Family on the bench? Between that and the Cremina you'll have the meanest 2-group that side of Turner Falls anyway!
PC
