Where to get a heating element for a Mini Gaggia?
Postby trollklint on Sat Apr 16, 2011 2:46 pm
Hi all! Does anyone know where to get a new heating element (220V) to a Mini Gaggia. My element seems to have a a short circuit, probably in one of the pins...
trollklint
Postby orphanespresso on Sat Apr 16, 2011 2:50 pm
You might be able to repair a short at the pin.
orphanespresso
Postby trollklint on Sat Apr 16, 2011 3:01 pm
Hi! :)
I will see what I can arrange ... I am not sure about the Mini Gaggians ends are sealed with epoxy putty, do you know?
trollklint
Postby peacecup on Sat Apr 16, 2011 4:01 pm
Hej Emil,
The heating element was fine for me - what are the symptoms? The only problem I ever had was if the contacts near the group got wet - they are open, and if wet will flip the ground breaker.
LMWDP #049
peacecup
Postby trollklint on Sat Apr 16, 2011 4:25 pm
Hej John :)
The problem arose after I changed the gaskets in the machine .. Probably a leaked on the right pin as you say... the result that there has been a short circuit in the element ... But the machine was in good condition when I bought it from you :) Nice machine by the way !
trollklint
Postby Warrior372 on Sat Apr 16, 2011 4:32 pm
Some water heater companies still have the still / capacity to make custom heating element coils. They may also be able to repair your's depending on the problem. So, I would recommend to look for a local one. There is a good chance that if they can not help you they will be able to point you in the direction of someone who can help you.
Warrior372
Postby trollklint on Sat Apr 16, 2011 4:34 pm
What about ?
http://valueheat.com/cartridge-heaters-...volts.html
I saw that you have discussed Incoloy in previous thread.. is Incoloy food safe?
trollklint
Postby trollklint on Sat Apr 16, 2011 4:35 pm
Warrior372 wrote:Some water heater companies still have the still / capacity to make custom heating element coils. They may also be able to repair your's depending on the problem. So, I would recommend to look for a local one. There is a good chance that if they can not help you they will be able to point you in the direction of someone who can help you.
TY for the tip!
trollklint
Postby peacecup on Sat Apr 16, 2011 4:51 pm
A cheap fix is one of these:
http://www.amazon.com/Travel-Immersion-...124&sr=8-2
Since it's an open boiler it can be inserted through the top.
PC
LMWDP #049
peacecup
Postby orphanespresso on Sun Apr 17, 2011 12:30 am
Still seems prudent to check it all out with an ohm meter, dry it out, and see if the short can be cured. The ends can be resealed. A short caused by water in the circuit behaves in a very specific way. Put your ohm meter probes in a glass of water, then on one element terminal and the body of the machine. If the meter behaves the same way there is water in the terminus.
orphanespresso
Next
