I rebuilt a Cremina this weekend, but have run into a bit of a pickle with the group.
the lower nut on the piston shaft is torqued down as far as it will go, yet it's not stopping the piston. Rather, the fork from the lever is hitting the top of the group (the "bell" if you will). The shaft is screwed into the piston as far as possible and all the parts are from the same Cremina. I didn't think to check before the tear down, but given the complete lack of wear on the group, it doesn't look like this happened prior to the rebuild.
Below are a couple of photos that should help explain my predicament.
Thanks for any tips/advice.
