timo888 wrote:It doesn't really matter (i.e. volume is not affected by) how long you hold the lever up, unless the water is flowing through the coffee in the basket into the cup. The coffee in the basket dams the flow (except for what it absorbs). The volume of the piston cylinder is the volume of the piston cylinder.
timo888 wrote:Howdy, Greg![]()
Rob, I never pulled a warming flush on the Cremina, but your understanding of the volume is correct -- the piston cylinder fills when you raise the lever and hold it up. Of course, with no PF in place, if you were to raise the lever only part of the way and let only a little water dribble out before pulling the lever down and closing off the port, the volume of water in that flush could be less than what the cylinder holds.
P.S. You must like higher brew temps. I think with all the flushing you'd end up with a fairly hot group. On your 8-second flush, does the water at first flash-boil and then become a defined shower-stream?
