by stepjunk on Thu Nov 29, 2007 9:57 pm
I am no electrician, either -- but the machine seems pretty straightforward. That said, when it did not work after I replaced the crumbled away and flickering old switch (that is, the new switch light came on, but no heat) and I had tested all the wires, I took it to the local electronic shop, who looked it over and told me the element was burned out. I'm not sure they knew what they were talking about--but I took them at their word and ordered a new element--stainless steel (new), to replace the old heavier element, which is copper (?) and much more substantial. I put in the new element--all pretty straightforward --and still nothing. The switch light goes on, but no heat.
So... I started looking at the replacement switch, wondering if that was the culprit after all.
Bob, I'll try the test you suggest and see what that tells me. If that's not it, I guess I need to start at the beginning again, with renewed patience.
I've got half a mind to bypass the switch altogether, wire it direct off the plug, then plug it into a multistrip and use that as on/off power, just to see if the machine heats up that way. That's probably pretty crude, but that's where I'm at. Anybody with any suggestions or experience at tracking down this sort of thing, I am in need of encouragement and welcome advice. Many thanks.
