So when I found an old Pavoni on spanish E-bay it both seemed nostalgic and convenient to go for it.
It came the other day, and the big parcel contained a sleeping beauty, that yet had to be awakened..
It turned out to be one of the oldies, probably from the 60ies or seventies. Full of scale and the chrome seemed pretty wasted. Had to descale it with vinegar, since descaling agents apparently don't exist in Iceland (don't think they have calcium in the water)
After descaling ( worked fine with vinegar!), I was in for some serious polishing, and the chrome was actually a lot more well preserved than I first thought. Here it is:
As you can se, it's a the model where the grouphead is attached with four bolts to the boiler, which has the same size as the professional, it does not, however has a pressure gauge on top of the sight glass. Moreover the grouphead itself seems a bit different than on the newer pre-millenium versions. Someone once told me, that in the old models, they used to have a termosyphon-ish system, which has now been reintroduced in the millenium.
Furthermore there is only a minimo-massimo switch and no thermostat. When temperature is reached there is a hiss from the OPV which indicates that pressure is reached, and as far as I know, then you just brew, while putting the switch to minimo.
Now was the time for heat-up, it warmed up fine, I was surprised by the hiss, since I first later read this is intentional in these models, and brewed my first cup. Came out ok, with crema of descent thickness, there was however a leak in the upper parts of the piston. So I decided to disassembly the grouphead ( a thing I normally did with the other used pavonis I've had, to check the gaskets). Here is the grouphead
The O-ring at the showerscreen looked OK, but when I tried to get the showerscreen of, by applying force to the top of the piston, nothing happened, could not by any force loosen either O-ring or showerscreen.
I noticed that the showerscreen has a brass-ring in the eccentric part towards the O-ring, as you see here:
I haven't seen this on my other Pavonis, and has no idea of how this is attached with the rest of the group, so this could be why I can't loosen it.
So, has anyone a clue on how these oldies are constructed in terms of the group-head?
Could be interesting to see photos or diagrams of other machines of these decades, and get some experiences to get on with.
So any knowledge would be appreciated, I don't dare to just apply more force, in risk of breaking something that might prove impossible to replace.
Best regards
Ulrikmo
Ps: Hope you'll be able to see the photos, have never tried to upload images before..
