by orphanespresso on Mon Dec 21, 2009 11:26 pm
Obviously different schools of thought on the pstat repair. A new mater or CEME pstat would likely do just fine....the mater has a real nice close deadband and will fit in the machine. The original pstat has such a hefty brass look to it that it is hard to resist repairing it. Lots of different rubber to try if one has the patience...reinforced and otherwise, and I don't think it defaults to overpressure but underpressure so it is not dangerous but aggravating to redo it over and over until one gets the right combination of rigidity and elasticity. But again, upgrading (?) may be the least aggravating way to go. The fact that the membrane in the body of the old pstat was originally a sourceable part from the manufacturer indicates the intent that this thing last a long time with very few moving parts and one wearable part and one wearable switch.
As an aside and part of the argument, I personally REALLY like the old style Olympia pstat....some of these are at top function after what, 25 years of service. The big counter spring on these gets weak eventually and little mods can be done to keep them adjustable within a good working range with about a .2 bar deadband. A MATER, notorious for sometimes lasting a couple of years more or less, is a kindof disposable part with a .1 deadband generally. I like the .2 or even larger deadband as one can pull on the upside or the downside and use the range for some actual temp management and in some ways an even wider range could be desirable for some people, even if just for experiments and observations. So there are arguments each way on old parts vs new parts.
