'Q' wrote:Although I'm no expert, I doubt they fused two alloys when building the tank. Instead I would guess that leaching either from the metal to the water or water to the metal has caused the internal surface of the boiler to change color.
timo888 wrote:I was hoping the interior was copper plated, but I gather not. Haven't heard back from the company that does FDA nickel plating.![]()
Regards
Timo
espressme wrote: What has happened is that you have "pickled" the surface with the cleaner. That removes all the elements other than copper from the surface. During smithing of copper, bronze, and brass; that is the usual effect after annealing when the fire scale is removed by acid etching. But, that is not the only process which does that.
That pure copper surface is only a few molecules thick.
timo888 wrote:What is that whitish-gray powdery coating that keeps appearing?
Regards
Timo
