Very old Europiccola gasket replacement
Postby Sean on Mon Oct 29, 2007 1:38 pm
Has anybody ever replaced the gaskets in an old (say, 1960s) Europiccola. I know I cannot buy a kit for them, but I'm wondering if anybody has exact demensions, or if there is anything special about the type of rubber, etc. so I can order custom gaskets.
My machine still works, and I love it, but it is starting to leak. I'm not exactly sure it's age, but it is the old model with the metal toggle switch that you have to unplug in order to turn off.
Thanks!
Sean
Sean
Postby mogogear on Mon Oct 29, 2007 7:43 pm
Actually you are mistaken- you can buy all the seals you might need-
Check out or contact Stephano at Espressocare
http://www.espressocare.com
He has very reasonable parts prices, is a member here and can be very helpful also.
There are several websites to refernce you to when you need help in how to install the seals etc.
Let us know when you are ready
greg moore
Leverwright
LMWDP #067
mogogear
Postby ideor on Mon Oct 29, 2007 8:11 pm
hello sean,
on la pavoni europiccola and ambassasor models circa 1960-74 it is necessary to unthread the cylinder from the group body in order to replace the seals.
the process is discussed in this earlier h-b thread:
http://www.home-barista.com/forum...ed-help-t4309.html
best wishes with your machine,
ideor, next door in albany
ideor
