VAM Caravel v1 microswitch - Page 4
A faemina is 800 plus 200 watt , so 10 A is for full steam ahead at 120V vs 5A or so at 230V.cuppajoe wrote:Thanks, will keep that in mind. Is that 9A on 120V or 240, with or without both elements going? With electrical, I like to leave lots of headroom.
A switch only just capable of the current/voltage will fail sooner than one with headroom, so if you can add some...
LMWDP #483
- cuppajoe (original poster)
Why I was concentrating on 15A, wanted to find something that would work anywhere. Have a candidate on the way.
Thanks to all for joining in the hunt, there's got to be something out there. Finding an original with maker's markings would be helpful. So far Francesco has'n't come up with a replacement, so maybe he's exhausted his junker supply. My guess is the original was robust enough that failure was usually due to water or some other physical damage.
David - LMWDP 448
Iguess that the original did not bother with the option of 120v ..."so anything you find that works is a great find!
LMWDP #483
- drgary
Figuring out how to rewire these for 120v all the way through would be great since we now have access to 120v heating elements.
LMWDP#308
LMWDP#308
Add a SSR seems an easy option, provided there is room to put it...not sure how the microswitch is operated but that way you could even use a reed switch or something similar inside the housing of it to operate the ssr
LMWDP #483
Really no room for an SSR, tho some folks have run outboard PIDs. The Arrarex has a complicated method of temp control, with the kettle clicking into place turning the machine on, then the system cycles power with a rocker bar moving in and out to activate the microswitch.
Here's the whole assembly
Here's a closeup of the switch.
And here's the metal bar at the back of the kettle that pushes on the rocker.
David - LMWDP 448
- crazy4espresso
I have two Caravel switches that do no match the VAM the OP posted. The link posted earlier works for mine, except I want higher than 6 amp rating.
I believe this will work?
http://uk.rs-online.com/web/p/microswitches/8486354/
"I would rather suffer with coffee than be senseless." — Napoleon Bonaparte
LMWDP #427
LMWDP #427
Thanks.
However, 10A 250V would be right at the limit for 120V and 15A should give plenty of headroom. And if not using an exact match, the most important physical dimension would be width, 11.45mm/.45", keeping in mind that it does go in a tight spot.
David - LMWDP 448
- crazy4espresso
I thought it meant 10A up to 250v? Guess i'll have to keep looking.
LMWDP #427
LMWDP #427
From what I gather, if it's spec'd 250V 10A, the amperage spec would be lower for 120V. Sometimes they do indicate that the amperage spec is across the board, which would seem to indicate it's rated for the lowest voltage listed.
David - LMWDP 448
