All completed. (Easy and Safe) As Doug stated in his post all fittings are 1/4" BSPP. You need.
1/4" Vacuum Breaker #1
1/4" Female/Female union #3 - Basically a short piece of brass with a 1/4" BSPP hole threaded right through.
3 x Copper washers
NOTE : the image was taken AFTER the job was completed.
Part #1 on the image is the Vacuum Breaker
#2 is the Safety Valve
#3 is the Female/Female union
Unscrew the Safety Valve from position #4 and screw the Vacuum Breaker into the same hole ( using one of the copper washers ).
Unscrew the Cap from position #5 and screw on the Female/Female union using a copper washer.
Screw the Safety Valve into the Female/Female union using a copper washer.
Turn the machine on and allow it to come to temperature so you can check for leaks. BE VERY CAREFUL as, to be able to see any leaks, the covers must be off the machine and electricity is deadly.
If there is a small leak just tighten a little more. ( Turn the power off each time you touch the machine with the covers off - I even unplug it)
NOTE : It is important to use copper washers between the fittings as these threads are BSPP ( British Standard Parallel Thread ) and, as Doug says above, they will not seal with teflon tape.
NOTE : This mod is only for the earlier Creminas which have the the full width cross bar
John
