AndrewYabsley wrote:Also - the Dow 111 - is this what you used to lubricate the piston as well ? not sure if the piston is considered part of the 'group' or not yet ... newbie.
I did try the BIO-LUB and it worked ok ... but not as well as I would have liked. The lever sometimes stutters or slips a bit when pulling a shot... but it has always done this and it's minor.
stefano65 wrote:Is this a machine with the plastic sleeve or
pre millennium?
uscfroadie wrote:Sounds like your lever pin and roller need to be lubed. Any time I feel any notchiness (stuttering as you mentioned), this is always the cause.
I use Dow 111 for the piston and shaft and Orphan Espresso's pin lube for the pin and roller, though Dow 111 will work fine there too.
Hope this helps!
