Bluecold wrote:http://www.hitechseals.com/chemical-compatibility.asp?chemical_id=1504
This is a massively useful link.
H/T to gamgra
thanks...goto get with it
AndrewYabsley wrote:For a long time after pulling the lever up or down an extremely fine black graphite-like residue would be left on the each side of the top of the portafilter. What the hell was that ? I must be crazy.
Did you have to remove the group from the boiler and then disassemble the group to get at the gasket ?
Chert wrote:I think it is finely corroded metal from parts (although well lubed) sliding against one another. Maybe it is dust that catches in the lube. I gradually get a bit of a built up as well where the top of the shaft slides up.
stefano65 wrote:the reason why I was asking if yours has a sleeve or not
is because sleeves
gum up from coffee residues and will make ALSO make a lot of resistance on the piston
eventually sleeve will also warp and crack,
so from the all good point from previous reply look at the sleeve as well
