Hi Larry
Short test for olympia cremina is very easy.
- Turn on the machine and let come up pressure
- open steam-valve a short time and let come up pressure a second time.
- let now work the machine 10-15 minutes for heating well all parts.
Now turn OFF the machine.
Do NOT open steam valve.
After cooling down enough (i think +-20 minutes) the lever of the cremina should go a bit up, because there is a vacuum in the boiler -> the seals are OK
- If the lever goes not up, seals are no more perfect.
When you can do a well espresso use your machine quietly and order a full replacement set or a piston set by
http://www.olympia-express.ch/ServiceSupport.asp or
http://www.orphanespresso.com/index.php?main_page=index&cPath=6_28. You will see the right time to change it.
after replacing you can work a long time, because newer seals are better than older. olympia sell a lot of seals of EPDM.
Best regards from switzerland
hope you understand my terrible english
nils
