by ziobeege_72 on Thu Aug 13, 2009 7:35 am
In my experience with a Pavoni EP you certainly can and should have an excellent shot if the extraction time is around 20 seconds, which should be in ristretto territory. However this does require a decent amount of resistence in the lever pull down - to the extent that you need to hold down on the boiler cap as you depress. You have to work for that espresso man! If you are not finding this, and that your pull down is "easy" with little resistence, then you will get bitter/underextracted shots. This comes down to tamping, grinding and dosing. A full dose, with a hard tamp/coarser grind or soft tamp and with finer grind should give you good results,
The other cause of bitterness is water that is too hot. The Pavoni's are notorious for overheating, even after a single shot if you dont allow them enough cool down time, or use ice cubes or cold damp cloths to force the cool down more rapidly.
