Used Europiccola with cracked heating element - Page 2
Postby coelcanth on Tue Feb 23, 2010 5:01 pm
hi,
I am looking for some parts for an early europiccola as well, mine was damaged in shipping and the steam valve/knob assembly itself got terribly bent.. newer parts won't fit..
if you are replacing yours maybe you can help ?
coelcanth
Postby darrensandford on Tue Feb 23, 2010 6:00 pm
I tried to get the steam knob off, but it seemed stuck fast. I will have another go and see how I do :)
*EDIT* - I managed to crack the steam assembly off of the boiler. It seems intact - knob, valve and wand. Any use?
darrensandford
Postby KnowGood on Tue Feb 23, 2010 7:56 pm
darrensandford wrote:I may have something that might interest you.
pm sent! :)
Lyndon
_________
LMWDP #251
KnowGood
Postby darrensandford on Wed Feb 24, 2010 2:30 pm
darrensandford
Postby coelcanth on Wed Feb 24, 2010 2:59 pm
thanks for the help !
here is a picture of the internal differences of the valve i mentioned
hopefully not as confusing
top assembly is from a 1964 Europiccola
bottom is from a ca. 1990's machine
http://www.flickr.com/photos/coelcanth/4384814793/
either way though, i could probably use the entire valve/steam wand assembly if you don't need it
coelcanth
Postby darrensandford on Wed Feb 24, 2010 3:42 pm
This one is definitely has a pin holding the knob to the valve. I held a ruler up to the boiler mounting thread so that you can see if this unit would be a slot-in replacement for your existing one, so that would (hopefully) solve the problem.
EDIT: I just unscrewed it from the valve - measurements to follow!
darrensandford
Postby mikekarr on Wed Feb 24, 2010 3:43 pm
The top assembly looks like the one from my La Cara. Functionally the same, but slightly different cosmetically. Could never get that allen screw out.
LMWDP #235
mikekarr
Postby darrensandford on Wed Feb 24, 2010 3:48 pm
Right - this one is definitely like the bottom one in your picture. The pointy end is 6mm, the shaft above the inner thread is 7mm.
I suspect that it won't fit your existing valve, as it is too new same as the bottom one. I can still send the entire unit if that would help, assuming it will fit the thread on the boiler.
darrensandford
Postby ademello72 on Wed Feb 24, 2010 11:56 pm
Hi Guys,
For what it's worth, similar to mikekarr above, I've also had multiple La Cara's with the "top" steamvalve, and had them replaced with the "newer" smaller steamvalves, and unless I have been very lucky ( now 4 out of 4) the steamvalves have all worked without a problem - I'd give it a go
Good Luck
ademello72
Postby coelcanth on Thu Feb 25, 2010 2:41 pm
thanks for the tips !
it's good to know I can use the later part if i need to..
ps.:
I couldn't get the allen set screw out of the knob either ! but it succumbed to the drill press
coelcanth
PreviousNext
