Typical Sound of Olympia Cremina Lever Operation? - Page 2
Postby tekomino on Mon Oct 24, 2011 3:20 pm
Yes, on Cremina at least half pumps will circulate water and heat the group up: When filling lever machine cylinder, where does the air go?
Refuse to wing it! http://10000shots.com
tekomino
Postby orphanespresso on Mon Oct 24, 2011 3:24 pm
The sound on the video does sound like a seal noise and not metal to metal...the sound of the seal rubbing on the cylinder wall.
orphanespresso
Postby peacecup on Mon Oct 24, 2011 3:35 pm
If the Cremina is designed that way, I stand corrected. I don't think the Ponte Vecchio works that way, but I've never considered it. In fact, I never preheat the group, prefering to brew at a cooler temperature.
But what sense does it make to heat the group with half pumps while leaving the seals dry? Why not just purge a little water through the whole group, thereby lubing the seals too?
PC
LMWDP #049
peacecup
Postby Slow Turtle on Mon Oct 24, 2011 3:46 pm
orphanespresso wrote:The sound on the video does sound like a seal noise and not metal to metal...the sound of the seal rubbing on the cylinder wall.
Thank you Doug! I'll stop fretting now. :D
Slow Turtle
Postby Slow Turtle on Mon Oct 24, 2011 3:48 pm
bigstormgirl wrote:I have the new 2011 also, and I get this noise too. But not all the time. The noise reminds me of the old paper cutter boards when you lower the blade.
That's EXACTLY what it sounds like.
Slow Turtle
Postby Paolo on Mon Oct 24, 2011 8:06 pm
Hi Slow Turtle,
On watching and listening to your clip, it sounds like at the bottom of the lever's travel it is actually hitting the top of the bell. "clink!" Is that happening?
Paolo
Postby farmroast on Mon Oct 24, 2011 8:18 pm
I let just a little water through to wet everything then due half pulls to heat to desired temp. while saving water.
Ed Bourgeois
LMWDP # 167
http://coffee-roasting.blogspot.com/
"Bezzera Strega" the newest WMD in the LMWDP
farmroast
Postby Climb14er on Wed Oct 26, 2011 4:34 pm
On my Cremina 67, I bleed off some of the excess pressure through the steam wand and then about thirty seconds or so later, I simply lift the lever up 2/3 of the way, to allow the hot water to enter and circulate the head and then out the head.
Then I put the empty basket under the head and give it another 2/3 lift, with water heating up the basket and out the bottom of the head. Bleed off a little more steam from the wand, and then I'm ready to pull the shots.
Been doing it this way for MANY years and the machine, with only one rebuild earlier this year has been making fine espresso. :wink:
Have fun!
Climb14er
Postby samuellaw178 on Thu Dec 15, 2011 4:03 pm
Sorry for reviving this 2-month-old thread but I think this is probably the most relevant topic for it.
As mentioned here, I did notice some metal-to-metal sound on my Cremina occasionally. But I didn't give it too much thought because I couldn't pinpoint the exact cause.
Today I disassembled my group head for lubrication and I noticed something I didn't before. Either it wasn't there before or I overlooked it. There is actually a small brass surface exposed because of worn off chrome most likely due to metal-to-metal rubbing(between inner lever fork with group head). For those of you who actually think that you have metal-to-metal sound (especially you have the older cremina), you might need to pay more attention. This isn't a damage per se; just a very minute issue that causes no problem at all. You won't actually see it unless you took the whole lever pin out like I did. Just thought some of you might wonder where the metal-to-metal sound came from if you have it. But I can't be 100% sure that the sound is coming from this rubbing but it's a very likely candidate. I applied a little lube there just in case.
samuellaw178
Postby Possepat on Fri Jan 27, 2012 12:45 pm
Didn't want to start a new thread so I figured I'd just add my question to this one.
Any other Cremina owners out there experience a "ticking" sound from within the case? It's not an overly concerning sound, maybe akin to the element in a baseboard heater expanding (ticking) but I just wanted to make sure it was normal, or at least experienced by others.
"It becames my passions"
LMWDP #365
Possepat
PreviousNext
