by orwa on Thu Feb 14, 2008 8:28 am
The La Pavoni Professional I got used was also set near to 2 bars when I got it (meaning that the pressurestat, an electrical component at the base of the machine will cut the current when the pressure in the boiler reaches around 2 bars, this component has a screw in the middle that can be played with to adjust this threshold pressure). The pressure gauge is also likely to be one of the older ones advising higher pressures than the newer versions. In my case the pressure gauge stopped working after a couple of months of operating the machine, and I realized after buying a new one that I was accustomed to relatively very high pressures both for brewing and for steaming. My advice is to adjust the pressurestat as soon as possible for ultimate steaming (1.0 bar is really enough), and to manually turn the machine off upon brewing to facilitate avoiding burnt shots (Note however that you can pull good shots with 1.5 bars of pressure, that is, the temperature of the boiler water and the pressure are to a large extent of little relevance to the brew water temperature, the most important factor however is the thermal condition of the group... THIS is the most important factor, the water at the boiler is at temperatures higher than 100 degrees centigrade and is always ready to burn pucks).
I hope this helps lengthening the life of the pressure gauge you have. This is because the La Pavoni gauge is pretty, pretty expensive, and because the newer gauge is in my opinion uglier, and thicker than the older one (it's no longer wholly in chrome, brass or gold but has come to have a black plastic casing with only a chrome, brass or gold frontal circular frame).
Note: More than two bars is a very high pressure I believe for pulling shots, it corresponds to a higher temperature of the boiler water and thus, makes the heat-sinking job of the grouphead a more difficult one. It's difficult to avoid burnt shots when pulling at more than 2 bars of pressure. The point I believe is to use the least pressure enough to pump water to the group, 0.8 or 0.9 bars are enough in my case, turn the machine off, pull, turn it on again, fill the pitcher, it's 1.0 bar and you're ready to go.
