yakster wrote:Before you pull the shot with the La Peppina, are you doing partial pumps to load the puck with water and start the pre-infusion?
yakster wrote:Note, with singles, you don't want to wait the ten seconds, just load up the puck with a few partial pucks and go otherwise you'll overextract.
samuellaw178 wrote:I did do the partial pump to load the puck with water. However, my Peppina seems to require more partial pumps than I see in the videos. This probably means my Peppina is not releasing as much water if I just let it raises for a few inches, I have to let it raise further. If I do that (ie let the lever raises further), will it create vacuum and cause channeling? Bear with me for the questions as I do not really understand the mechanism behind this nifty Peppina pump even after many readings.
samuellaw178 wrote:I have read the "What Else Tastes Like a Peppina" thread too but I was trying to refrain from using so much coffee. On my Gaggia, I could create a ~1.75 oz intense shot with just 14g. But 14g shot in Peppina is pretty mild, even in just ~1.25 oz. My mind keeps telling me that "this can't possibly be right" to use so much coffee just to get the same intensity shot from Gaggia. I can accept it if the intensity is the same between 1.25 oz Peppina's shot and 1.75oz Gaggia's shot, naturally, due to its lower pressure. But "mild" shot in 1-1.25 oz is too much for me. It is even using slightly finer grinds than the Gaggia. My main concern now is channeling issue as I do not have a bottomless pf and I think channeling will lead to this result.
samuellaw178 wrote:Thanks for the heads up on the single. Duly noted.
samuellaw178 wrote:Even though this issue is bothering me somehow, she is still pulling spectacular shots. It is in a totally different league from the pump machine in term of its supremely sweet, smooth and balanced shots. The subtle chocolate taste previously in Gaggia was made even clearer by Peppina. I am enjoying espresso as straight shots much more than before than with my Gaggia. It's just that I am greedy to want to make strong shots that cuts through milks in Cappas.
samgiles wrote:Looking at your video it looks like you're having to do rather a lot of pulls to get any amount of water through. This could be due to the 2 washers not being seated nicely or the washers being old and a bit hard. Have you replaced the seals and washers at all? Those 2 washers are fiddly. They have to be sitting just right and have enough flexibility to allow the water past them. Are you getting water coming back up into the kettle?
yakster wrote:That's great, I really enjoy the straight shots on the La Peppina. I'm not much of a Cap drinker, but will occasionally make one for the Wife or company.
As for the video you uploaded, the technique looked pretty good to me, as far as I could tell. I say that you just need more practice and make sure to enjoy the homework.
