kitt wrote:Did the switch on the front panel have a high/low setting? this would indicate it would have had an emissions valve with no pstat installed.You set it to high for initial warm-up, then low for idling, and the emissions valve lets off excess presure.
cafebmw wrote:gaggia oriones from the 70's came with a 5 position switch (0,1, 2, 3, 4).
cafebmw wrote:these are 110v elements. if i had a 220v hookup only (for enough amperage reserve), i'd wire the elements in line. therefore only on/off would be possible.
use heat resistant wire, not the regular one. they will work for a couple of years but then start drying out and cracking.
cafebmw wrote:the sirai stats are perfectly fine on the gaggias. i just bought one from doug for $55 for my 1954 esportazione. dial in the deadband to 0.9/1.2 bar.
