duke-one wrote:it seemed all he did after basket prep was to pull the lever down, pause, then let it up, so where does all the control I'm reading about come in?
I'm video-challenged (when it requires "Flash") so I just have to imagine what people are seeing, but what you're describing is a SPRING lever. The spring is an extra component: instead of driving the piston directly, you cock a spring and then it drives the piston. Why? Because you don't want that control, I guess!
I have two, both spring levers, but on the smaller domestic size one, the lever is attached to the piston, such that I can if I wish push the piston down by pulling up on the lever. Handy, if you accept the notion that the spring will normally do a better job than you could of controlling the piston but sometimes may want some extra force to overcome a dose that was too full or too finely ground. I doubt that this would apply to many of the high end machines you'll be likely to be looking at - as a general rule, the higher you go up the scale, the less control offered, so most likely when you pull your lever up, you'll pull only the lever, and exert no force on the piston.
This is not because control is bad for you, but because it's no use to the professional barista, who has no time to take advantage of it. Whether any professional barista actually uses a lever today or not, the contradiction-in-terms "commercial lever" is still the model that we follow, for better or worse.
(My car is a '73.)
