I use a La Pavoni Europiccola, and I've recently been timing my pulls. I find that (excluding the pre-infusion time, which is usually about 10"), the lever pull varies between 15" and 35" (depending on the usual variables, and some that I can't work out). The shots taste different, but almost all are acceptable. I was wondering if I should aim at a narrower range of times, which would effect how much pressure I put on the handle.
So, it occurred to me to ask how much time spring-loaded levers are set to take to pull a shot. I suppose they vary, from machine to machine, and also depending on the resistance they encounter from the puck (quantity of coffee, grind, tamp etc). But is there a more-or-less usual time?
