orphanespresso wrote:the question would be....were the terminals melted before this mystery event?
orphanespresso wrote:So let's say they were melted, which happens when the connections become contaminated and dirty and the terminals act as a small resistor and produce heat thus melting the cover, which is usually nylon or other fairly low temp plastic. Let's say that the thermal switch developed a dead short, which in effect replicates touching the two wires of the power cord together, which usually draws enough amps to blow the circuit breaker...most are rated at 15 amps for home current. Let's speculate that you perhaps have 20 amp circuits in the kitchen and the thermal switch dead shorted....the amperage on such an event would have to exceed the 20 amps in the breaker box to throw the breaker, which it did not, but the components of the machine are mostly rated at 15 amps and the wires of the machine likely 30 amps, but the terminals plastic covering not so high a rating. Let's say you have a 15 amp circuit in the box....this would protect the 15 amp components of the machine and likely throw the breaker thus protecting the parts.
orphanespresso wrote:It is frustrating when there is no obvious causal event to make a part fail like this
orphanespresso wrote:but there is always the outside possibility of a power surge on the line, which usually fries the heating element, if the heating element was in the ON mode when the surge happens, such as when first turning on a cold machine. So if there was a power surge and the pstat was OFF, then no current would reach the thermal switch OR the heating element. If there was a surge and the pstat was in the ON the current would go through the pstat to the thermal switch and possibly over amp the switch BEFORE getting to the element, thus giving a sort of fail safe fuse.
orphanespresso wrote:I bet that if one inspects all of the amperage ratings that the thermal safety switch has the lowest rating of all the switches on the machine and would act as a sort of internal surge protector to keep the element protected for any over amperage event.
orphanespresso wrote:Of course it is possible that the switch decided to crap out just at that moment and it has nothing to do with anything other than timing.
TUS172 wrote:Hm... I am kinda stumped on why the unit won't fire up if you replaced the P-stat and and the Switch.
roadman wrote:I swapped the thermal safety switch and now the heating element works again.
