Chert wrote:I don't follow the point that insulation of the boiler would lead to a higher temperature of the group or greater heat transfer into the group. The central relation seems to be temperature and pressure governed by the setting of the pressure stat.
If it isn't too late to comment on this - that's true, but I think you would agree that if you could raise the temperature of the boiler itself (as opposed to its contents), assuming the boiler is attached to the group and that it's massive enough to make a difference, that excess temperature will transfer to the group.
So (it seems to me) it comes down to whether insulation really does make the boiler much hotter. My intuitive notion is that it depends on how effectively the contents maintain temperature. If temperature can be maintained at the inside surface of the boiler, then I would expect the boiler temperature will be maintained as well, since the boiler metal is much more heat conductive than the air around it. But if the temperature next to the inside surface drops, as heat is conducted out due to lack of insulation, of course the boiler temperature will drop as well.
Of course that's just idle speculation. I regard our uninsulated boiler as a auxiliary heat source for the kitchen. We have fewer hot days on this side of the mountains - may not have any this year.
