Heilmittellehre wrote:I bought some Tanzania Peaberry from a local roaster. So far, I've pulled 4 doubles with it (2 doubles per day), and had the same strange experience on each day. The morning shots flow so easily that I'm tempted to grind finer. The afternoon shots nearly choke the machine. I use the same weight of ground coffee each time. I have not adjusted the grinder. I tamp until the top of the tamper is level with the top of the basket, so I assume the force has been the same. I always fill the boiler before I use it.
I don't know what the difference could be--the relative humidity? It has been cool enough that I've had the air conditioning off. Thoughts?
You're saying you're tempted to grind finer but you don't?
Probably residual grinds have overnighted in the grinder, making the morning espresso flow faster.
