clynch wrote:And that would indicate that backing off on the pressure decreases the turbulance in the potafilter. Higher pressure , increasing turbulance, or, a pattern of movement "within" the portafilter vice "through" the portafilter.
clynch wrote:Higher pressure , increasing turbulance, or, a pattern of movement "within" the portafilter vice "through" the portafilter. Perhaps the decrease in pressure allows gravity to have a higher impact which adds to throughput.
tekomino wrote:Rather, imagine a bed of small pebbles with space around them for water to flow. If you push harder the pebbles will be forced closer together making less space for the liquid to flow through. Less pressure allows for more space between pebbles and thus greater flow.
