IMAWriter wrote:As I've never used a spring lever, I'm wondering (versus a manual lever) the strength needed to initiate the pull on a spring lever...that is, the downward pull before releasing the lever for it's spring assisted journey back up.
Would the force needed be equal to, less than or the same as the force downward I use with my Cremina?
TIA
timo888 wrote:
[snipped]
However, the spring lever requires the barista to have much greater intelligence and good looks than a manual lever requires.
timo888 wrote:Sounds as though you tend to overdose and pull ristretto.
IMAWriter wrote:Timo, if 1.5oz from a Cremina with a 13.5 to 14 gram load at 30 seconds(including a 6 second hold at the top) qualifies as a ristretto, so be it! BTW, there is still a 2mm clearance between the top of my dry puck and the lip of the basket.
I always thought my 9 gram in a single basket .75oz pulls were ristretto pours, based on coffee amount, versus liquid produced. Truthfully, I'm not quite sure what constitutes a "strict" ristretto pour, if there is such a thing.
IMAWriter wrote:if I try a 1/4 pull "Fellini" thing, the lever will get stuck when I re-raise then attempt to lower the lever, unless I grind to salt consistency
timo888 wrote:Pull according to your tastes, of course, but if your extraction stalls after the preinfusion, that's typically the result of several grams overdose, though this can happen if you grind finely, tamp with force, and updose by only a couple of grams, especially if you pull with too much force: excessive brew pressure can stall the flow.
This is where micro-adjustment on the grind really pays off.
P.S. Going by volume can be misleading.
michaelbenis wrote:Rob are you saying it chokes after your 1/4 pull?
Cheers
Mike
With the spring there is no wiggle room in the pull pressure to "save" the shot and when you lock in the pf the die is cast.
... Cremina 67 ... heard it is more tolerant of up-dosing ...
Bluecold wrote:With coupled spring levers (MiniGaggia, Peppina, others) the die is not quite totally cast since you can help the lever upwards if you've ground too fine. Or slow it done if you've ground too coarse. They are specifically designed for the semi-intelligent people.
