timo888 wrote:Thanks, Paul, I appreciate the offer very much. I would consider custom made if nothing can be found off-the-shelf.
We have two options. We can replace the original spring with a heftier one, or we can augment the original spring with a second one with wire on the thin side.
Hefty single spring:
Approximate length: 85mm
Maximum outer diameter: 44mm
Minimum inner-diameter: 15mm
Wire thickness: 5-6mm
Lighter weight ancillary spring:
Minimum inner diameter: 30mm
Wire thickness: 3-4mm
Regards
Timo
espressme wrote:Have you tried "Lee Stock Springs" http://www.leespring.com/?
Spring Calculators:
http://www.engineersedge.com/spring_comp_calc.htm
and:
http://www.efunda.com/DesignStandards/springs/spring_calculators.cfm
timo888 wrote:Thanks for the sources, Richard. I had begun to look but had uncovered nothing as extensive as Lee. I like that they have a metric option
Regards
Timo
P.S. But minimum quantity 10
mandioca wrote:would motorcycle springs possibly be useful? either new say from http://www.progressivesuspension....springs/index.html or used from a junkyard, used motorcycle fork springs could be picked up quite cheaply and would give you many options in spring rate to choose from. they would of course not be food safe but, depending on application that might not matter, or a treatment like this http://www.kgcoatings.com/additional.html#1 could be used. I have used both Gearkote and Gunkote, mostly on motorcycle parts, but also on a doserless spout I did for a Rossi RR-45, it really works quite well.
this is my first post here
