Soon to Be Lever Lover
Been pulling shots on a cheap little Breville Barista Express now for a few years learning some of the ins and outs of espresso. Recently started using a popper to roast my own beans from sweet Maria's and my obsession has gone to the next level! I'm ready to upgrade to a lever style machine and want some advice regarding where to start! I've looked at a few online and read things here and there but haven't got much feedback on various brands and models. I know a quality grinder is a MUST and i think I'll be going with the LIDO E by Orphan Espresso. A lot of research has be sold on that particular model!
I'm only barely familiar with two machines the La Pavoni Europiccola and the Olympia Cremina. I see those two a lot and they seem to differ in price drastically depending on the year. I would like to keep the cost for the machine under a thousand if I could. If anyone has any input on which models they think I would be happy with and why that'd be a huge help! Looking to be a regular around here so thank you for the responses in advance. Cheers!
- redbone
If you don't need steam and only make espresso, also consider a Arrarex VAM \ Caravel.
Semper discens.
Rob
LMWDP #549
Semper discens.
Rob
LMWDP #549
- Balthazar_B
IMHO, for that price, and with the need to steam, you'll have to decide between trade-offs.
If you're handy and a tinkerer by nature, your best choice would be to refurb a vintage machine, if you can find one at a good price (also meaning the cost of replacement parts won't be crazy). Done right, arguably that will give you the best outcome, especially if you have the option to plumb it in. The cost of your own labor not included, you could probably do OK within your budget.
If you want new, a Cremina will be way over your budget. There are a few boiler-fed lever machines like Ponte Vecchios and Pavonis, and it's possible to get good espresso out of them with a fair amount of study and practice (temperature control is usually the challenge with these machines). Or you could get an espresso-only machine and an separate milk steamer. If you can hold your horses, the Cafelat lever machine described in this thread could well be worth waiting for, especially if Paul Pratt can sell it for $300 or less. Arguably the best pure manual lever machine is the Strietman, but it's above your budget, and frankly you'd do better putting that money into a better grinder than the Lido E -- although I have a Lido 3 and think it's fine; I use it for pourover and press pot brewing.
Just some ideas.
Just some ideas.
- John
LMWDP # 577
LMWDP # 577
- jone9081
For that budget with steam it sounds like the La Pavoni Europiccola is likely the front-runner.
LMWDP #542
People say the Pavoni has some issues with temperature. As in to hot or what?
- MB
Depending on which generation, it can be like catching a runaway train. If you do it just right and pull at the correct temperature as is passes, you can get a beautiful ride. Without temperature tracking, I was more likely to get run over.
I added a simple digital thermometer as seen here Adding Thermometry to a La Pavoni Europiccola and was able to get consistently nice shots.
LMWDP #472
I have a restored first-gen LP, and once you get the routine and the *feelz* of the machine, it is simply a matter of adjusting half-pumps.
- redbone
You can always get either a separate steamer or frothier for under $100.thomasben wrote:Steamer is essential
Semper discens.
Rob
LMWDP #549
Semper discens.
Rob
LMWDP #549
- drgary
You can also get a restored or mint condition first generation La Pavoni Europiccola for well within your budget. Those first models had high build quality, were the most temperature stable and were the underlying machine for the first generation Cremina. Boiler size is limited, though. How many people do you serve in a session, and how many of those are milk drinks? Another option is a used/good condition Elektra Microcasa a Leva.
LMWDP#308
LMWDP#308
