I read a lot (sweetmarias, lesson from Chris ect.. I see all Utube videos) but is not working
I have now everything working with the machine new gaskets around good pressure and temp.
I use a compak K6 grinder,
grinds ( from coarse to fine ) Until I found some resistance on the lever
Now I'm two clicks from 0 in the K6
The tamp
Here you can see some results
I've tried everything more coarse more & less tamp
more fine by tho clicks by one....
I'm turning little crazy ....
What I'm I doing wrong ..........
1 heat everything
2 charge PF
3 up the lever just until water comes out to avoid the suction
4 insert the PF
5 the rest lever up about 10 secs
6 then slowly pull down the lever
At the beginning looks like ok, dark and good crema, but when the lever is in the mid way turns in resistance (Channeling???) and the crema goes out more white
Any help is super welcome xDDD
Thanks
