Well, you know although I've been making espresso nearly daily with this machine for about 6 years now, I still feel like a beginner. I am a complete beginner when it comes to using the bottomless portafilter. I have read some tutorials, and seen a bunch of videos, but the nuances are perhaps lost on me until I have more experience pulling shots with the BPF.
Through research here and on another coffee forum, and trial and error, I have found over the years what tends to work well for me.
I don't switch espresso roasts very often, having settled in on Black Cat Espresso from Intelligentsia, mainly because I find it pleasing and also they have conveniently opened several locations in Los Angeles, including one in Pasadena, where I live. Back in 2004, before they opened their first LA shop, I was taken to their flagship shop in Chicago by a good friend I was visiting. He's a coffee and espresso nut too, and I was impressed with the espresso the Barista pulled for me that day, and I left with 2 lbs. of Black Cat to take back home with me. For a while I was ordering and having it shipped to me on a semi regular basis. Now it's just a short drive to pick it up locally. Of course the price has gone up over the years, so it seems like I'm paying as much for it locally now as I did when I had it shipped!
Anyway, back when I first got this machine, I was playing around with 30 - 40 lb. tamps, and finding it tricky to dial in the right grind so as not to choke the machine and to extract the best shot I could. With a lot of experimentation, and a gnawing feeling that I shouldn't have to work the lever so hard in order to get a good, sweet shot of espresso from the machine, I started playing around with considerably lighter tamping, and have settled in on around 4 lbs. or so with an appropriate grind allowing for about a 25 sec pull. Well, for me it was a revelation. I was able to get consistently great shots from the Cremina, with far fewer sink shots, and a lot less pressure on the lever. I still have to exert force, but now it seems like a reasonable and safe amount of effort compared with some of my early experience going by the book.
Well, if you're still with me, I still play around with the variables and am still chasing the so called God shot, and hope that the BPF will help me to further refine (or revolutionize) my technique.
I made this first video, and will continue to make some new ones from time to time to see if I can glean some insight into what I could be doing better.
Some of the things I have learned from reading up on the subject and viewing other BPM video clips is that good things are: even initial dispersion of water through the puck and portafilter evidenced by uniform trickling of water through the basket bottom screen, that becomes a conical centered single funnel after say 8 - 12 seconds. Also, tiger striping of the stream is a good thing. Not seeing premature blonding of the shot is also sought after.
Bad things are: multiple streams, and or a conical stream that is not centered, spraying, early or complete blonding, lack of tiger striping, etc. These can be indicative of channeling due to poor distribution of grinds in the portafilter and/or poor tamping technique. There are all kinds of things that can be diagnosed by viewing a shot pulled with a BPM, but since I am new to using a Bottomless Portafilter, I am still trying to learn the nuances of what I am looking for.
Here's a guide from this site that explains a lot of what one would want to look for:
http://www.home-barista.com/naked-extraction.htmlAs I mentioned in my first post, I was hoping some more experienced Baristas here with both BPMs and perhaps even owners of Olympia Creminas might be able to give me a critique and some suggestions to try.
From what I can see, compared to other videos I've seen, the tiger striping can be more pronounced and perhaps have tighter striations between the lighter and darker parts of the streams. Also, I wonder if the beginning of my extraction showed less than ideal evenness of first drops through the bottom screen of my PF basket. Does the timing of the various parts of the pull seem right to others with more BPM experience?
I started the count of my shot extraction from the beginning of my preinfusion, which I would say is at 00:11 into the video clip.
Anyway, if anyone cares to give an opinion or a suggestion for improvement, I'm all ears.
Mahalo
