KnowGood wrote:Mike,
I think all this can be "fixed" with the grind. Small adjustments will still allow you to leave no headroom but accommodate the coffee. I use 2 different coffees, two different grind settings (both from the same roaster - if this matters) and get the same results. All I can suggest is to play around and see if it works out in your favour.
Hi Lyndon,
Sure. I could adjust the grind to get the extraction I want with the dose that packs up to the shower screen - and that would work great with some of the beans I use (I'm a bit of changer - often having as many as 6 different beans in 250g packs per month, though they all get cycled over the year - maybe twice as many different SOs in the course of a year).
I'm particularly fond of Ethiopian single origins in the Elektra Microcasa a Leva, which is fussier than the Pav about updosing. It also produces exceptionally clear, delineated shots which are magic with an Ethiopian Sidamo, Yirgacheffe or Bale Wild Bean. Some of this spectacular delineation (which works so well with these SOs and in these cases yields a far superior shot to the Cremina, Pav or Caravel in my opinion) is lost to an extent if you dose up to the screen.
On the other hand I am able to avoid channeling with careful distribution, a fine grind and light tamp, so I am quite happy.
Another single origin I am fond of comes from Java and is a tremendous chocolate bomb that is quite happy being updosed to the hilt in the Cremina, where it produces a complete difficult but no less spectacular result.
As I said.... horses for courses. I'm sure your method is working a treat for your beans in your Pav.
Cheers
Mike
LMWDP No. 237
