by damiani on Fri Nov 30, 2007 10:26 am
I've had a Europiccola for about 10 years, and in just the last few weeks I've been noticing a fair amount of sediment at the bottom of otherwise tasty shots. As far as I can tell, I've changed nothing--I'm using the same beans I always use, ground on the same setting (moderately fine in a Rancilio Rocky), and the same pull technique.
My only guess as to the cause is that I need a new portafilter basket; is it possible that the holes have begun wearing out to the point that it's allowing grounds through? (Visually, though, I can't detect any wear.) If so, what's the typical life span of a portafilter?
Thanks,
Keith
