by Anvan on Sat Nov 26, 2011 12:33 pm
The interior pipes in a LP have roughly the diameter of a freeway drainage culvert, so that would have to be some kind of scaling to bring a La Pavoni to its knees.
Assuming your unit is firing up, boiling and pressurizing properly, the first thing I would check is the group piston's position on its shaft. When you raise the lever, the shaft pulls this piston upward until the water entry from the boiler is exposed, enabling the water to enter the group. But if the piston gets loose and unscrews somewhat, the piston gets too low on the shaft and won't clear the water inlet when the shaft is raised.
The fix, of course, is to disassemble the group (there's plenty of advice and instructions for doing so on this site!) and retighten the piston to its proper position on the shaft.
Don't feel singled out by fate - the "unscrewing piston problem" is famous among La Pavoni users, especially with machines that came equipped with the Delrin (I thick that's right) pistons. These replaced the brass pistons for a time, as LP hoped this high-density plastic would mitigate the group's heat retention tendencies. But ... they also tend to unscrew: I have two LP Pros, identical save for one having the plastic piston, which unscrews every three or four months - the brass piston, never.
Predictably, replacement pistons in brass are a frequent purchase of LP owners of that era.
I hope this turns out to be your fix - it's an easy one, so good luck!
