peacecup wrote:The tube that feeds the group is probably clogged with scale. You'll need to remove the group and descale it. It will require all new seals and gaskets. Probably not too difficult or costly, but will take a little time. Most difficult part is removing the piston. Read up on it before you do it.
OR, just send it to Doug at orphanespresso.com, and it will come back as good as new.
I really like my PonteVecchio Export, which is a very similar machine,
PC
ademello72 wrote:Hi DHR,
Just wondering where you picked up the SAMA? I'm also in Bellingham WA, and don't see anything other than La Pavoni's locally
Cheers
Anthony
I'll have to decide whether to keep the Sama or Elektra
DHR wrote:I actually picked it up on ebay. I've also looked around locally for a long while without any luck. I also have a Elektra MicroCasa on the way!. I'll have to decide whether to keep the Sama or Elektra as I don't the room to keep both. If you looking for a lever machine I can drop you a line when I decide which one I am going to part with. -luke
