Thanks a lot Robert for the reply,
I hope now you have the time to enjoy your life and excellent espresso shots!
Strongly acidic water..., especially in water with high chloride content because of the formation of chloride complexes, both with Cu2+ and Cu1+.
. Most probably the water in Athens has high chloride content, but it is not very hard. The water I use for the espresso machine is always coming from a Brita to reduce the chloride & the hardness.
When you clean with acetic acid do you get a blue solution? Blue, of course, means you are slowly dissolving your copper boiler!!!
I use only 50% water (from the Brita) and 50% white vinegar and very rarely citric acid (not with vinegar). I do not know if vinegar contains acetic acid.
The water coming out during the descaling does not have any color at all. It looks like tap water. I boiled some water in the machine. Got it out through the group, let it get cold and tried it. It tasted ok, very similar taste to the water Brita produces.
Cu2O is reddish, CuO is black.
In my case, the color is rather reddish, not black. I tried again scratching the boiler with my nails. Does not feel list "dust". It seems like the color of the boiler has changed.
From a corrosion standpoint it is highly preferable to use distilled water.
I have tried pure distilled water from a drugstore. My conclusions:
* Hard to find. Not every drugstore here has it available.
* A bit expensive, since I have to throw away a liter of water for every espresso I make. Distilled water can not be store because it does not contain chloride. Correct ? So after the coffee, I have to empty the machine and throw the water away.
* Distilled water if not stored properly can be contaminated. I do not know how supermarkets store it. Because of this I prefer to buy it from drugstores.
But I also prefer the taste of espresso made with distilled water. I know it is better for the Europiccola. I compromised with the Brita.
Is there a way I can get rid of this reddish color ? Do you think it is dangerous to use the machine ?
