HB wrote:I've seen spent pucks with tops as smooth as the countertop and others that looked like moonscapes. If there is a correlation between the puck's surface after depressurization and the taste of the espresso, I've yet to discover it. In barista competitions, the tech judges only look for consistency; whether the spent pucks are firm as a brick, mushy, or in between, they don't care, as long as they're the same shot-to-shot.
Anyway, although I'm not into puckology, I agree with the above posters that the Fellini Move will likely disturb the pristine nature of the puck's surface. The cause was more evident when I started using a bottomless portafilter with the Ponte Vecchio Lusso because with the bottom open to the air, it was easy to hear the sucking sound of air being drawn through the puck when recocking the lever.
Back to the original question: Rob, do you correlate a taste defect with the rough surfaced pucks? Or are you grasping for justification of an upgrade?
