My cherished friends here...
I decided to ignore some (well intentioned) advice and try something different.
Instead of loosely locking in the PF until I was 2/3rds the way on the up stroke of the lever, then locking in, I tried locking in the PF all the way
before starting the up stroke, then slowly raising the lever.
At the top, I did a small 4" down stoke, then raised the lever up, counted to 5, then lowered, with firm even pressure...about 35lbs, as usual. the pour was monkey tailed, striped, and dark brown, not black...temp was good. I reached the end with no blonding whatsoever. 1.25oz all crema.
I customarily swirl the shot glass once...just a 1/4" of black.
Tasted wonderful. All the components sang...10 day old Black Cat (which is all Brazilian), 20% home roasted Colombian Pitalito (cherry-ish), and 20% home roasted Yemen Sharisi (spice.)
Another thing...I really overfilled the PeDe...18 grams ground for the OEM Cremina basket...rapped down on the grinder to dislodge stuck grind to get it all.
Dosed using the WDT, and gently rapped the PF down on the tamping surface once. I did a NESW finger distribution. I believe I had about 14 grams in the basket. A 30 lb tamp left about 3 millimeters from the top. The most I ever packed in there. The puck was also perfect. Smooth, no crevices, etc. And it ejected with no layers.
I've always been afraid of overdosing...not anymore.
My new espresso arrives with a client from Chicago Friday. Kid-O, and fresh Black Cat, plus my own blend. No time to get him to stop by Metropolis..
I bet I can loosen the PeDe now...it was about as tight as I could get it, but it didn't seem to make the burrs lock too much.
my Doserless Rio from my great friend Jon R arrives tomorrow. However, I am impressed by how evenly the grind emerges from the PeDe. Hand grinders rock, and mine will be my night-time grinder. This is gonna be fun.
Thanks to all who have stuck with me here. Y'all rock.
