Robo-Pavoni; learning to make espresso machine from scratch - Page 3
Postby Droshi on Sun Aug 17, 2008 11:42 am
I'd like to see a detailed walk-through for drilling that pressure gage into the GH. If you're taking requests :D
Droshi
Postby matadero210 on Mon Aug 18, 2008 9:17 pm
A quick reply: use two drills, one superfine from the bottom of the head, and the second 0.125 from the side. Hope they meet and drill carefully while paying attention to desired depth. The superfine hole should be outside the piston shroud, but inside the screen and o-ring. Once you see daylight, epoxy a 0.125 stainless tube into the hole and add a gauge.
LMWDP 117
matadero210
Postby Droshi on Tue Aug 19, 2008 3:45 pm
Very much appreciated.
Do you have any problems with coffee grounds getting stuck in that small hole? Looks like it would be the best spot for it, but I do still get grounds up in that channel after some shots.
Droshi
Postby matadero210 on Thu Aug 21, 2008 10:59 pm
Grounds may get in there, but I've never had a problem with that. 10 bar keeps the tube clear. The volume in the gauge fittings is filled with water, so very little displacement is needed in the tube.
r
LMWDP 117
matadero210
Postby SandBaggerOne on Tue May 04, 2010 10:55 am
What year was the group you used to make your Robo-pavoni? If your measurements in the Cad drawing are in inches they seem a bit different relative to the 1982 group I have.
Cheers,
Colin
LMWDP #310
SandBaggerOne
Postby matadero210 on Mon Sep 05, 2011 10:23 am
Not 100% sure what year--I got rid of the body some time ago. But I've drilled two of them so far, both pre-millenium, and not seen any important differences.
-raj
LMWDP 117
matadero210
Previous
