Riviera/Ponte Vecchio Portafilter Gasket Size
Does anyone know the exact size of the portafilter to group gasket of any of the Ponte Vecchio machines?
I just found out that their piston seals are interchangeable, as the Riviera piston seals are no longer available.
I need to replace the portafilter gasket on one of my Rivieras that I'm trying to sell.
The measurements of the Riviera portafilter seal I have are:
(OD)55mm x (ID)43mm x (Thickness)5mm
Thanks
Thanks
- crazy4espresso
The older Riviera groups with the 3 piston V seal configuration is the exact same as the Ponte Vecchio Export. Same portafilter gasket. I have restored 4 older Rivieras.
"I would rather suffer with coffee than be senseless." — Napoleon Bonaparte
LMWDP #427
LMWDP #427
Nice! Thanks again.
I went to a place called Hannah Rubber in town and will be having some made (in viton rubber) for less than I found them for online. I bought the V seals from 1st line at $10 each. Kinda steep.
Im working on 3 Rivieras at the moment.
