www.artazza.com: exquisite demitasses and handcrafted TORR tampers
Ristretto in a hand levered machine? - Page 2
A haven dedicated to lever espresso machine aficionados.
Link to "Ristretto in a hand levered machine?"by happytamper on Tue May 02, 2006 11:22 am
The Zassenhaus is great, You will adjust the grind alot but this is something you get used to. I enjoy the manual aspect to it, No noise. And when I have a friend over they have to work for their coffee. It takes around 1 to two minutes to grind enough for a shot. Great to feel the way the coffee is being ground as you turn the handle.
I also just ordered the Isomac Gran Maccinino, that grinds directly into the portafilter. It was a great deal for the Home Barista anniversary from Chris coffee. It is for my studio when I have to make a number of coffees for my students and myself. The Zassenhaus is great and beautiful but you may get frustrated when you have to make more than one or two shots.
Mitchell
LMWDP #77
happytamper
Link to "Ristretto in a hand levered machine?"by GaggiaGirl on Tue May 02, 2006 11:37 am
Perhaps I will seek one out, then. I like the ritual of the whole process, so a hand grinder seems like a great addition to my set-up. I barely ever make more than a couple of shots, so it should be perfect.
GaggiaGirl
Link to "Ristretto in a hand levered machine?"by kbuzbee on Tue May 02, 2006 1:22 pm
GG - I use a Zass 175M (the brass Turkish mill) every day for my Europiccola. 2-3 shots a day. It takes 110 turns to grind up a whole chamber of beans. The grounds holder (the bottom) then slides off and fits right into the filter basket. I do it over a small bowl and it makes very little mess. This process makes slightly more ground coffee than the LaPa filter needs but the little waste is small price for a very simple proceedure.
FYI - prior to than I used a Zass 171KD (Wall mounted, very nice). It also did a great job but the impeller went loose so its on its way back to Germany for repairs right now. High end powerful grinders are great but the quality, price and quiet of the Zass is how I chose to go (and I'm happy with the choice).
Ken
LMWDP #054
kbuzbee
Link to "Ristretto in a hand levered machine?"by peacecup on Tue May 02, 2006 1:45 pm
GG, welcome to the forum.
I've been using hand grinders for years. They're probably slightly less consistent than a very good electric grinder, but they work fine. I place two scoops of whole beans in the top, and around 50 handle-turns later I have enough finely-ground coffee pull a lovely doppio. It can grind fine enough to jam a lever, or for that matter, a pump machine. I love the grinding ritual. I dose by covering the wooden drawer with a card with the corner cut off, which allows me to fill the portafilter without any spillage. No mess, no noise, and tasty espresso. If you get one be sure that it has forged burrs and is in very good condition, or it may not grind fine enough for espresso. Cheers,
PC
Hand-ground, in the cup:
LMWDP #049
peacecup
Link to "Ristretto in a hand levered machine?"by HB on Tue May 02, 2006 8:18 pm
another_jim wrote:My turn to eat humblepie ...
Oh pshaw, I enjoy regular servings. As we discussed offline, the SCAA conference / USBC / EspressoFest was my heaping helping. :shock:
peacecup wrote:Hand-ground, in the cup:
Nice color and mottling!
Link to "Ristretto in a hand levered machine?"by ian2kris on Wed May 03, 2006 11:21 am
I have been very interested to read Dan and Jim's analysis of what is and isn't desirable in a competition shot. Where can one learn more, and how are the standards set? Also, how closely tied do you think these characteristics are to exemplary flavor?
Ian
ian2kris
Link to "Ristretto in a hand levered machine?"by another_jim on Wed May 03, 2006 5:03 pm
The score sheets and other rules are downloadable from the SCAA:
http://www.scaa.org/about_usbc.asp. Shots are rated 0 to 6; with 0 being bad, 1 poor, 2 average, 3 good, 4 excellent, 5 godshot, and 6 a posthumous award by a judge dying of ecstasy.
I like my coffees acidic, my roasts very light, and my shots rather hot and ristretttoish, around 205F, with a shot start that drips and gets gushy towards the end. Consequently, I get crema that's darker on the outside than the center. Better looking crema for me means a much less tasty shot (although I was kind of surprised how poorly my crema rates). This type of idiosyncrasy wouldn't fly in Barista competition (not even personal baskets are allowed - I for instance prefer Faemas to LMs for this sort of blend and shot). Instead one has to make do with the baskets and machines provided, and one must grind and dose them for a very even flow beginning to end to get a uniform crema (and to satisfy the technical judge who would be handing out 1s for the way my espresso flows). The blend needs to be chosen to taste spectacular subject to these constraints.
I'm no longer as certain as I used to be that my technical eccentricities produce tastier shots -- I had some very excellent and ego-deflating ones at Charlotte. However, I'm still not enamored with this USBC and WBC "technique strait jacket;" I think it retards pushing the envelope by the very people most qualified to do so and most likely to produce really stunning improvements in fundamental technique. Figure skating started with skating figures -- i.e. perfect circles, figure 8s, etc. Then they added the free competition, where people could (gasp) jump. Finally they abolished the figures in figure skating. I somehow think that skaters today are somewhat more proficient than they were in 1920. It's a lesson the barista championships need to learn.
another_jim
Link to "Ristretto in a hand levered machine?"by KarlSchneider on Wed May 03, 2006 8:12 pm
another_jim wrote:I like my coffees acidic, my roasts very light, and my shots rather hot and ristretttoish, around 205F, with a shot start that drips and gets gushy towards the end.
I have been reading Jim Schulman for years. Almost all the time I am completely frustrated with his views. This quote is wonderful. It say it all and so perfectly.
I, on the other hand, hate acidic coffees. See my constant whining about Kona espresso's and earlier Brazil's. I like my roasts on the dark side but I am backing off the darker ones. This week I think I over-roasted two Yemeni just slightly. I much prefer less than hot shots. I actually agree with Jim on the drip to gushy shots.
My point is: figure out what you like. I have no doubt that Jim likes the shots he describes. I can taste his and have no interest in tasting any ever. Au contraire, I understand that he would throw mine down the sink.
Ths is an essential insight for all of us.
Thanks Jim for the lesson.
KS
LMWDP # 008
KarlSchneider
Link to "Ristretto in a hand levered machine?"by HB on Wed May 03, 2006 10:04 pm
ian2kris wrote:Also, how closely tied do you think these characteristics are to exemplary flavor?
Taste is what matters, though appearance is often an accurate leading indicator. To put it in terms of barista competitions, refer to the sensory judge's score sheet:
Taste Evaluation of Espresso:
  • Color of crema (hazelnut, dark brown, reddish reflection): 6 points
  • Consistency and persistence of crema: 6 points
  • Taste balance (harmonious balance of sweet/acidic/bitter): 6 points x 4
  • Tactile balance (full bodied, round, smooth): 6 points x 4.
The taste and tactile balance are weighted x4. The color assessments we've been discussing accounts for 6 points out of 60 (note: crema recovery can be tested by a "spoon drag" through the crema as part of the consistency / persistence score). Plenty of espressos look gorgeous but disappoint in taste; though generally speaking, the first two scores (color, consistency) together usually correlate with the latter two (taste, tactile balance).
Link to "Ristretto in a hand levered machine?"by kbuzbee on Thu May 04, 2006 8:29 am
HB wrote:Taste is what matters, though appearance is often an accurate leading indicator. To put it in terms of barista competitions, refer to the sensory judge's score sheet:
That's awesome Dan, but can anyone quantitatively lay out, what percentage of those scores are the coffee and what percentage are the skills of the barista??? I've had some coffees (the one I'm drinking right now) I can't seem to screw up. I've had others I have to work very hard to get anything I want to drink. So I know it isn't ALL skill of the barista.... Whadda ya think?
Ken
LMWDP #054
kbuzbee
Link to "Ristretto in a hand levered machine?"by bobcraige on Thu May 04, 2006 9:15 am
Dan
Is there any standard color chart provided anywhere to define the color in espresso?
Bob Craige
LMWDP #7
bobcraige
Link to "Ristretto in a hand levered machine?"by GaggiaGirl on Thu May 04, 2006 10:23 am
Thank you everyone for your inputs on hand grinders. I think I will go that way. If anyone has any suggestions on where to get one, that would be great. I'll be on the road to great espresso in no time!!
GaggiaGirl
Link to "Ristretto in a hand levered machine?"by peacecup on Thu May 04, 2006 2:16 pm
Hello GG,
Ebay has them periodically. You should be sure that it has a stepless adjustable grind (not a locking nut on the top of the axle), either on top, back, or in the drawer. Look for those with SS or white enamel bowls inside- they seem to be higher quality (although the new Zasses may not have these?). I would ask the seller to test the adjustement to see if it will grind fine and evenly, and ask about damage to the burrs, rust, etc. I've gotten a couple that don't grind fine or evenly enough. Good luck,
PC
LMWDP #049
peacecup
Link to "Ristretto in a hand levered machine?"by HB on Thu May 04, 2006 8:19 pm
kbuzbee wrote:I've had some coffees (the one I'm drinking right now) I can't seem to screw up. I've had others I have to work very hard to get anything I want to drink. So I know it isn't ALL skill of the barista.... Whadda ya think?
Some coffees are definitely more forgiving. Another possible explanation for the "I can't screw it up" phenomena is your expectations. What I considered acceptable two years ago is an insult to my driptray today. As Jim mentioned, the bar moved up considerably between SCAA conferences. For example, the same shots that elicited cries of wonderment in Atlanta 2004 were greeted with yawns in Seattle 2005.
Andy pulled shots on Gimme Coffee's pressure-profiled Cyncra with the most lusciously rich crema in recent memory. At one time you could reliably best just about any cafe's espresso in your own kitchen. Nowadays there are more and more "serious" cafes and home baristas cannot make that boast without first checking who's in the room. The bar is moving up in terms of barista skills and the coffees they use.
bobcraige wrote:Is there any standard color chart provided anywhere to define the color in espresso?
A standard chart? Not that I'm aware of. It would vary anyway depending on the blend. Everyone agrees that pale blond = not good, flecking / tiger striping = good, after which the discussion of the finer points begins. That was several hours of lecture and calibration exercises at the USBC judges' certification workshop.
Link to "Ristretto in a hand levered machine?"by kbuzbee on Fri May 05, 2006 8:48 am
HB wrote:Some coffees are definitely more forgiving. Another possible explanation for the "I can't screw it up" phenomena is your expectations. What I considered acceptable two years ago is an insult to my driptray today. As Jim mentioned, the bar moved up considerably between SCAA conferences. For example, the same shots that elicited cries of wonderment in Atlanta 2004 were greeted with yawns in Seattle 2005.
I hear what you are saying, Dan. I thought my shots were amazing when I first got my Euripiccola. I'm sure I wouldn't want even the best of those today. I am always trying things to tweak my shots... some work... most don't :D But I try because I want to constantly improve my coffee. I hadn't put what I said earlier into that context. I can see looking back 2-3 years from now (if this were possible) at some of these "can't screw up" shots and going "What was I thinking?".... Maybe.... I kinda hope so, else not much has changed. Have to say, what goes into the tweak is less varied these days. Small adjustments. I guess I'm finding my "zone".
You say it used to be simple for a home barista to slaughter the output of a cafe but less so today.... I would counter with - The Home Barista, with care and understanding, can produce the shot you want, at the cafe, you will get the shot the cafe wants to pull (if they are good!)
Ken
LMWDP #054
kbuzbee
Previous
